I want to refresh the data the grid is displaying. Does the grid provide a client side function to refresh itself using AJAX?
Hi Fesani,
Please refer
http://ko.infragistics.com/community/forums/p/38704/461827.aspx#461827.
I dint see response. Would you kindly take this up and provide a sample on what Angel Todorov has suggested and reply me asap.
Its blocker issue for us and highly in need of help from IG team.
Glad it helped.
This really helped. Thanks a lot :)
you can do the post back for example on the SelectionChanged Event of a WebDropdown.
function cboAAA_SelectionChanged(sender, eventArgs) {
document.getElementById("<%= cmdDoRefresh.ClientID %>").click();
update panel and trigger
<asp:UpdatePanel ID="UpdatePanel1" runat="server">
<ContentTemplate>
<asp:Button ID="cmdDoRefresh" runat="server" Text="Refresh" />
<ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="350px" Width="977px" AutoGenerateColumns="False"
DataSourceID="SqlDataSource1" DataKeyFields="MainKey">
******here the bound columns ******
</ig:WebDataGrid>
</ContentTemplate>
<Triggers>
<asp:AsyncPostBackTrigger ControlID="cmdDoRefresh" EventName="click" />
</Triggers>
</asp:UpdatePanel>
What is firing the RunThisAfterAsyncPostback() call? I've tried to run the example code but javascript is not firing.
