265
Textbox in Grid Cell
Hi, i am trying to add a textbox to a grid column that i am creating at runtime, but i am unable to find out how to do it.
I notice when you set a cell to be updatable, it doesnt render a textbox, rather just <nobr> tags. I am not using viewstate, so on a postback, i need to recover any values that have changed in teh grid, from the request and restore first before do the postback code, please help.
Rob
  • 12025
    Hi Rob,
    When you set a column to be editable, the textbox will only appear when you try to edit the cell. You can set edit actions via the "EditModeActions" property group under cell editing.
    If you want to show the textbox at all times, then you will have to use a templated column and host a textbox inside of it. You can get and set textbox values on the server side by doing find control on the template.
    Hope this helps.
    -Taz.
