565
More ig_common..
I copied the Infragistics images over to a folder on my web production server.  (\\Server\Infragistics\Images)
Setup a the ig_common virtual directory and pointed it to the folder where my images are located
However, after deploying the ASP.Net solution to the production web server, no images appear on my Infragistics menu control or dropdown box controls.
My understanding is the Infragistics controls look for the ig_common virt dir for the images location..
What did I miss?
Thanks!
  • 270
    If the Virtual Directory is setup in IIS, then are you sure that permissions are appropriately granted?  ig_common should not point to your images directory directly, rather it should point to the root of the infragistics tree.  Images should be a sub-directory under ig_common.
