I am trying to create an in-memory dataset. Initially this dataset will be populated from a feeder database, but once I have the data, I will close the connection and work completely with the in-memory dataset, saving it to a session variable as needed. When preparing the data for the charts, I need to do various SELECT statements on my dataset tables. How do you execute a SELECT statement on a dataset table that doesn't have any connection to an actual database?
This was the linq (pun intended!!) that I needed:
http://msdn.microsoft.com/en-us/library/bb669096.aspx
Take a look at this thread on the ASP.NET forums - http://forums.asp.net/t/1226738.aspx
You can't create a DataView from anonymous types, or from a Linq query that performs a Join. There are a couple of links in the thread which may provide some help for you.
-Tony
Yes, I think that LINQ TO DATASETS is what I need. Thank you.
This may not be the right place for this, but when I tried the LINQ on my VB2008 Vista-32-bit-business, I get an error. If you happen to know what the problem may be, please let me know.
Below is my code, along with the runtime error it produces. Does anyone have some suggestions for eliminating the error?------------------- Dim cht1tbl = MetDs.Tables("Charts").AsEnumerable
Dim query = _ From d In cht1tbl.AsEnumerable _ Select d!Jan_2006, d!Feb_2006
Dim cht1View As New DataView cht1View = query.AsQueryable
System.InvalidCastException was unhandled by user code Message="Unable to cast object of type 'System.Linq.EnumerableQuery`1[VB$AnonymousType_0`2[System.Object,System.Object]]' to type 'System.Data.DataView'." Source="App_Web_fuzhh4da" StackTrace: at _Default.LoadGrdData() in C:\Users\Paul\Documents\Visual Studio 2008\WebSites\TestGrid\Default.aspx.vb:line 33 at _Default.Page_Load(Object sender, EventArgs e) in C:\Users\Paul\Documents\Visual Studio 2008\WebSites\TestGrid\Default.aspx.vb:line 17 at System.Web.UI.Control.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) InnerException:
Take a look at this MSDN article on using DataViews http://msdn.microsoft.com/en-us/library/system.data.dataview.aspx This should be the missing piece you're looking for.
