665
Reload The Parent Page..
Hi All,
I Have a User Control.The UserContol have the WebDayView control and webschduleinfo control.The Control works fine for adding new activities(using mycustom page appointment.aspx.The appointment page is in inside a Master Page.And also I open as a Pop up window).My problem is when i Add a new activities using appointment page,the data is inserted into database,and also when i close the pop up widow,the Parent Page i.e the user control must be reload and update the new inserted activities.How to do this?
  • 24497
    To update a page from server you need to trigger a postback. To trigger postback you may call any of following:
    1. form.submit(); // to get reference to form you may use any <input>, document.forms, etc.
    2. __doPostBack("", ""); // or you may provide anyControlOnPage.UniqueID for first param
    3. anySubmitButton.click();
    If you close your pop-up from its local codes, then to trigger postback in it parent, you need first to get reference to its window. In most cases you may use "opener".
