50
Custom Add Appointment
I'm trying to create a custom AddAppointment dialog in VB.NET using a sql server backend.  The sample uses xml.  I believe I've got the Appointment extended correctly. I also created a page called addAppointment.aspx and AppointmentFormPath of the webScheduleInfo  control on my calling page accordingly.  At this point, my 2 questions are this.  How do I get a reference to the webscheduleInfo control on the calling page from the child AddAppointment dialog page? I'm trying to limit client side code as much as possible.  Second, once I do, What is the correct syntax for calling the Update(ByVal context As DataContext) method in my custom data class?
 -MJC
  • 245
    From AppointmentAdd dialog, I think you can only access the WebScheduleInfo object on the client side.  What I did was store the variables in Session so that the two forms can communicate. The Appointment Dialog has no server side events.
