90
Unable to load a chart using xml file
I have an xml file with following format,
When I create an xml datasource and assign it to chart datasource, it is not populating the chart based on the values in xml file. I was looking at Columns chart, where X coordinate is Year and Y-Coordinate is Interval.
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
<ReportPeriod>
<Period Duration="1 Year">
<Dur>
     <Year> 2 </Year>
      <Interval>60</Interval>
</Dur>
<Dur>
     <Year> 3 </Year>
      <Interval>30</Interval>
</Dur>
<Dur>
     <Year> 4 </Year>
      <Interval>20</Interval>
</Dur>
<Dur>
     <Year> 5</Year>
      <Interval>90</Interval>
</Dur>
</Period>
</ReportPeriod>
Any help would be appreciated.
Nat
  • 90
    Thank you
  • 28496
    Verified Answer
    the chart won't infer the schema from that xml file, so it doesn't know that the Interval column is numeric.  this will work, though:
    DataSet ds = new DataSet();
                ds.Tables.Add("Dur");
                ds.Tables["Dur"].Columns.Add("Year", typeof(string));
                ds.Tables["Dur"].Columns.Add("Interval", typeof(double));
                ds.ReadXml("..\\..\\xmlfile1.xml", XmlReadMode.IgnoreSchema);
                this.ultraChart1.Data.DataSource = ds.Tables["Dur"];
                this.ultraChart1.Data.DataBind();
