Thanks for the reply. I installed and while using the websplitter control i am facing the following issues..
Hi...
Actually the ListView control is causing the problem... Could you please try to add a list view control and check it in Internet Explorer 7.0. Its working fine with Internet Explorer version 6.0....
Wishnu
I have tried to remove some contents and tried. Even though the issue exists. Actually i am using 7 user controls . Out of which 5 controls are using the simple <asp:Table controls. Only two controls are having the GridView control. Could you please suggest some ways / forward this to your support staff,
Also i am using the trial version. Is the issues due to that?
Did you have a chance to try the suggestion above - removing some of the content to see if there is a specific control which is impeding the splitter from working properly? If you can narrow down which content is causing the problem, we may be able to find a way to work around the issue. If you need assistance from our support staff, I can have one of our Developer Support Engineers contact you.
-Tony
I am using the websplitter and in two webpart zones in it. Each webpart zone loads some 7 custom/user controls. While resizing with the splitter the websplitter have to runat server and again the loading of controls has to happen. This is not allowing to move the websplitter freely . Any way of simplifying that such as runat client level. Give some suggestions please.
It sounds like some of the custom controls you're embedding inside of the splitter pane is likely causing the problem.
The best bet is to try removing some of the content and see if you can find which control is causing the problems.
