Can I catch the event of a WebImageViewer in my .cs file.
Exemple: I want the client side event ImageClick.
I know in VB we can double click on a button and we have a line like that:
protected void WebImageViewer1_ImageClick(object sender, System.EventArgs e)
But with your controls, is it possible and in C#??
thanks you
Gabriel Deschenes
I made a scenario using FF 3.0.10 and FF 2.0.012, and ItemClick was firing perfectly fine. Here is the code I used:
1. JavaScript handler:<script language="javascript" type="text/javascript">function iClick(webImageViewer, eventArgs){ alert("image clicked: " + eventArgs.getImageItem().get_key());}</script>
2. Handler definition within image viewer:<ClientEvents ImageClick="iClick" />I am also attaching sample page.
Please note - this is only client side event. This means this event does not go to the server (your .cs file).
Hope this helps
Ivan,
The imageclick event does not fire in FireFox. I am using the exact code posted above.
Any sugestions?
You can use the analogous of client side event ItemClick - SelectedIndexChanged. Please take a look at the sample below: <ig:WebImageViewer ID="ImageViewer" runat="server" Height="150px" Width="500px" onselectedindexchanged="ImageViewer_SelectedIndexChanged"> <Items> <ig:ImageItem ImageUrl="http://news.infragistics.com/default.aspx" /> <ig:ImageItem ImageUrl="http://news.infragistics.com/Themes/infragistics/style/images/pods/Media.png" /> <ig:ImageItem ImageUrl="http://news.infragistics.com/default.aspx" /> <ig:ImageItem ImageUrl="http://news.infragistics.com/Themes/infragistics/style/images/pods/Media.png" /> </Items> <ClientEvents ImageClick="Fire" /> </ig:WebImageViewer>
Hope this helps.
