I have two barcode (3 of 9) fonts that I am testing in a ASP.Net application. One works well when I set a IText object's font.name property to it, the second does not give me an error, it just does not show in the document. Here is the code:
Dim rpt As Infragistics.Documents.Report.Report = New Infragistics.Documents.Report.Report() Dim sct As Infragistics.Documents.Report.Section.ISection = rpt.AddSection() Dim tx As Infragistics.Documents.Report.Text.IText tx = sct.AddText() tx.Style.Font.Name = "Code39_Barcode" tx.Style.Font.Size = 48 tx.Style.Font.Preferences.Embed = True tx.AddContent("*9288373*") Response.ContentType = "application/pdf" rpt.Publish(Response.OutputStream, Report.FileFormat.PDF)
I noticed that the font that works in embedded in the resulting PDF document whereas the one that does not work is not embedded.
Thanks for any help that you can provide
Ali
I believe that there are only a certain number of fonts that work by default with the Acrobat reader, and most likely it's true that none of these are the barcode fonts. I think that many fonts, in general, need to be embedded into the document in order to work correctly, especially Unicode or non-standard fonts. It may be that if the fonts are in installed on the system itself, they can be read, but I am not certain.
-Matt
