220
Bar Chart Y axis serieslabel problem... hoping for some help
Hello Experts
I am a beginner at using Infragistics and my first attempt at using the product has produced a bar chart that is close to what I want but I am having problems with a Y axis label.
the code that I am interested in is as follows (it is found in the html markup portion for my aspx page)
   <Y LineThickness="1" TickmarkInterval="0" TickmarkStyle="Smart" Visible="True">
                                <MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1"
                                    Visible="False" />
                                <MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1"
                                    Visible="True" />
                                <Labels Font="Verdana, 7pt" FontColor="DimGray" HorizontalAlign="Far" ItemFormatString="&lt;ITEM_LABEL&gt;"
                                    Orientation="Horizontal" VerticalAlign="Center">
                                    <SeriesLabels Font="Verdana, 7pt" FontColor="Red" HorizontalAlign="Center" Orientation="VerticalLeftFacing"
                                    </SeriesLabels>
                                </Labels>
                            </Y>
I found a sample on the infragistics site that looks pretty much like the chart I am trying to produce and it even has the html vb ASP.NET code to give me some clues on what might be wrong. But I can not figure it out.
http://samples.infragistics.com/2007.3/webfeaturebrowser/default.htm
My chart shows the view name in front of the field name. So it reads "vmychartdata_.Yes" instead of "Yes" and "vmychartdata_.No" instead of 'No"
I replace my SeriesLabels code with what I found in the example and I get the same results.
Results: "vmychartdata_.Yes" instead of "Yes" and "vmychartdata_.No" instead of 'No"
  <SeriesLabels Font="Verdana, 7pt" Visible="True" HorizontalAlign="Center" FontSizeBestFit="False" ClipText="True" FormatString="&lt;SERIES_LABEL&gt;" Orientation="VerticalLeftFacing" WrapText="False" Flip="False" FontColor="Black" VerticalAlign="Near" OrientationAngle="0"></SeriesLabels>
Any Ideas??
Renee
