First i was using the trial version and after getting the licence key i rerun the installer and entered the licence key. But still while adding websplitter / other infragistics controls am getting the version as ...
@ Register Assembly="Infragistics35.Web.v8.3, Version=8.3.20083.1009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.LayoutControls" TagPrefix="ig" %>
Any steps i have to do to get the licenced version.
The build number (8.3.20083.1009) is the same for both the trial version and the registered version. The differences are in the assemblies themselves and in the registry entries that we use to verify that a licensed version is installed.
Are you getting a "this is a trial version" dialog even though you've installed the registered version? If so, is this happening at design-time, runtime, or both?
I will clearly explain...
First i installed the trial version and used....Later i got the licence key provided and i uninstalled the trial version and reinstall the same by providing the key. Still while using the controls am getting the version number as 1009 which is for the trial version. Could you brief the steps / anything in prior to that?
After adding license key all controls of suit is activated. Is there any problem with licensing or I missing something?
Thanks.
