465
Client Side Event not firing
Hopefully I'm overlooking something simple.  Below are sections of my code.  The problem is that the click event does not seem to be firing.  I am defining the click event in the aspx.cs code, and including a javascript function in my .aspx client code.  What might I be missing?  Thanks for the continuing support!
From my .aspx file:
 <head runat="server">
    <title></title>
   <script id="igClientScript" type="text/javascript">
function UltraGauge1_Click(){
    alert("gauge clicked");
</script>
</head>
From my .aspx.cs file:
            ultraGauge1.Gauges.Add(myLinearGauge);
            //ultraGauge1.Gauges.Add(myLinearGauge2);
            ultraGauge1.ClientSideEvents.Click = "UltraGauge1_Click";
            ultraGauge1.DeploymentScenario.Mode = ImageDeploymentMode.Session;
           //ultraGauge1.DeploymentScenario.FilePath = "GaugeImages";
            ultraGauge1.ID = zone;
            ultraGauge1.Height = Unit.Pixel(50);
            ultraGauge1.Width = Unit.Pixel(400);
            ultraGauge1.TabIndex = 0;
            this.Controls.Add(ultraGauge1);
  • 28496
    replace
    with
            this.FindControl("form1").Controls.Add(ultraGauge1);
    ...if you look at the rendered html of the page, you will see why this is necessary.  calling this.Controls.Add on a Page results in markup added after the </html> tag, which can cause all sorts of problems.
