I woul like to know if it is possible to use a WebSlider with a composite chart to resize?
Thank you
the elements in composite chart cannot be resized without a postback, so it would be difficult and slow to trigger such an update using the webslider. however, if you want to resize the entire chart control, you can do that on the client, as long as you are using the flash or SVG renderer.
