444
WebDatatGrid sort on templated field?
Normal 0 false false false MicrosoftInternetExplorer4
http://ko.infragistics.com/dotnet/netadvantage/aspnet/webdatagrid/sorting.aspx
Hi There,
I have a sorting issue with the webdatagrid and perhaps you can help.
I am using a linqdatasource and the main table this is pointing to is a table of foreign keys mostly.
I am using Templated fields to bring in data from the other tables and hiding the Id fields.
See samples code.
<ig:TemplateDataField Key="RevenueLine">
                 <ItemTemplate>
                     <asp:PlaceHolder ID="plcRevenueLine" runat="server">
                     <%#DataBinder.Eval(DirectCast(Container, Infragistics.Web.UI.TemplateContainer).DataItem, "RevenueLine.REVL_Description")%>
                     </asp:PlaceHolder>
                 </ItemTemplate>
                 <Header Text="Revenue Line" />
             </ig:TemplateDataField>
             <ig:BoundDataField CssClass="hiddenColumn" DataFieldName="PRDM_CMPY_ID"
                 Key="PRDM_CMPY_ID" Width="0px">
             </ig:BoundDataField>
             <ig:TemplateDataField Key="Company">
                 <ItemTemplate>
                     <asp:PlaceHolder ID="plcCompany" runat="server">
                     <%#DataBinder.Eval(DirectCast(Container, Infragistics.Web.UI.TemplateContainer).DataItem, "Company.CMPY_Description")%>
                     </asp:PlaceHolder>
                 </ItemTemplate>
                 <Header Text="Company" />
             <ig:BoundDataField CssClass="hiddenColumn" DataFieldName="PRDM_PVTL_ID"
                 Key="PRDM_PVTL_ID" Width="0px">
My question is, can I sort by these items? For example when a user clicks the “Company” column, I want to sort the grid by “Company.CMPY_Description”. How do I set this up.
Thanks for any advice.
Chris in San Diego
