50
Need help on these Errors
Hi I am getting following errors in my ASP.net Application which uses Infragistic NetAdvantage_ASPNET_20081_CLR20_Product
I have tried complete unistall and reinstall but it still doesnt work.
Most irritating part is that the same source code working fine in other mahcines.
Please help
Error     478       The type 'Infragistics.WebUI.Util.Serialization.ISupportPresetSerialization' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics2.WebUI.Shared.v8.1, Version=8.1.20081.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
Error     475       The type 'Infragistics.WebUI.Shared.IUltraLicensedComponent' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics2.WebUI.Shared.v8.1, Version=8.1.20081.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
Error     481       The type 'Infragistics.WebUI.Shared.ISmartCallbackRender' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics2.WebUI.Shared.v8.1, Version=8.1.20081.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
Error     482       The type 'Infragistics.WebUI.Shared.IProvideStyleSheet' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics2.WebUI.Shared.v8.1, Version=8.1.20081.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
Error     484       The type 'Infragistics.WebUI.Shared.IProvideDefaultStyles' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics2.WebUI.Shared.v8.1, Version=8.1.20081.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
Error     483       The type 'Infragistics.WebUI.Shared.IProvideAppStyling' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics2.WebUI.Shared.v8.1, Version=8.1.20081.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
Error     486       The type 'Infragistics.WebUI.Shared.ILinkedCallBackManager' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics2.WebUI.Shared.v8.1, Version=8.1.20081.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
Error     485       The type 'Infragistics.WebUI.Shared.ICallBackResponseRenderer' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics2.WebUI.Shared.v8.1, Version=8.1.20081.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
Error     477       The type 'Infragistics.WebUI.Design.IProvideDesignTimeHtml' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics2.WebUI.Shared.v8.1, Version=8.1.20081.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
Error     476       The type 'Infragistics.WebUI.Design.IGetClientSideEvents' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics2.WebUI.Shared.v8.1, Version=8.1.20081.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
Error     479       The type 'Infragistics.WebUI.CalcEngine.IUltraCalcParticipant' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics2.WebUI.Shared.v8.1, Version=8.1.20081.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
