I don't see any properties that allow me to set the X Axis as a solid line (like the green line below)across the bar chart when some of the bar values are negative.
Any idea? Thanks in advance for your help.
Got it. Thanks for your help.
You can set the LineColor, LineDrawStyle, LineEndCapStyle, and LineThickness properties to customize the look of axis lines. In your case you can set following properties to set the thickness property of the X Axis;
this.UltraChart1.Data.ZeroAligned = true;
this.UltraChart1.Axis.X.LineThickness = 10;
