The following error is displayed when adding the control to a form:
Error Creating Control - WebDatePicker1
Failed to create designer 'Infragistics.Web.UI.EditorControls.WebDatePicker, Infragistics2.Web.Preview.v9.1, Version=9.1.20091.2011, Culture-neutral, PublicKeyToken=7dd5c3163f2cd9cb'
I have registered all the assemblies in the GAC. If I add a WebDropDown it works fine.
Thanks for any help.Ron
Hi Ron,
We have identified an issue within the designer dll and have publish a refresh of the CTP. Please download the latest bits from the website, and you should be able to get them working in the designer.
Taz.
I have the 9.1 RTM installed and I have a key. Maybe if you have exact steps I can follow I can see where I might be going wrong.
Ron,
I just tried it out and everything seems to be working ok... Do you have 9.1 RTM installed? As a trial or with a key?
I have verified both and I am still having this proble.
ThanksRon
Please make sure that you are use all 2.0 or all 3.5 dlls.
Also Infragistics2(35).Web.Preview.Design dll must be in the gac.
