1.) To "pre-filter" the data from a large table i do this in the
WebDropDown1_ItemsRequested - Event:
this.SqlDataSource1.SelectCommand = string.Format("SELECT IDX,PARAMETER FROM MASTER.K_PARAMETER WHERE PARAMETER LIKE '{0}%'", e.Value.ToString().ToUpper()); this.WebDropDown1.DataBind();so far so good, it works
2.) I've selected a value in the WebDropDown
3.) I fire a WebImageButton1_Click ... Event this.WebTextEdit1.Text = this.WebDropDown1.SelectedItem.Text;4.) Error: SelectedItem.Text is null
kind regards
Hi Angel,
I am facing the error while using WebDropDown.
There is a situation where i face this error against the following syntax.
WebDropDown.SelectedItem.Text = row["Name"].ToString();
I am using this code while trying to update record in database. On open function i use the above piece of code. I have saved the text of SelectedItem in database not value and my requirement is text not value.
Now i have to select the item from webdropdown for matching text.
EnableMultipleSelection is set to false.
I have not saved the SelectedValue in the database.
Kindly tell me how to select the item in webdropdown from text not value.
Regards
Sheeraz
Hello!
Yes, im clicking a value in the droped down list with the mouse.
Hi Andreas,
I think it is not related to the browser or the .NET framework (I have also tested with IE7 and 35SP1 btw) . It could be related to the databinding, yes. In general the WebCombo control is very different from the WebDropDown.
How do you select the item from the dropdown - by clicking on it with the mouse I suppose?
Angel
sorry: further the same exceptions.
Btw: could it be a framework (3.5SP1) or browser (IE 7.0.5730.13) problem?
When i'm using the webCombo with the property EnableXLMHttp an a DataSourceID, i cant access to the selected cells (Event
WebCombo1_SelectedRowChanged
e.Row.Cells[0].Text...
After switching to the following kind of databinding:
string
sql = string.Format("SELECT IDX,PARAMETER FROM MASTER.K_PARAMETER WHERE PARAMETER LIKE '{0}%'", this.WebCombo1.DisplayValue.ToUpper());
da.Fill(ds,
"VST01");
It works....
I am attaching a modified sample which uses the same properties and server-side filtering as in your example, and it works fine. If you can send me (attach) some WebSite sample that demonstrates this issue, i will take a look.
Also you can try removing the ValueChanged postback flag declaration, because it is not needed - when there is server-side filtering, an automatic filtering postback will be made and the value changed event on the server will be called anyway. (I didn't remove this in my sample and it works fine).
Thanks for the feedback,
