100
ColumnChart3D - annotations above each column not showing
  I had annotations above each column when the chart was in its flat version, but since I changed it to the 3D version I get the ChartTextAppearance( this is the object it was using to write out each column value right above the column) to show up?
Here is my code snippet for this issues
//labels above columns.
        if (showValues)
            //Appearance
            // ColumnChartAppearance     //      ColumnChart3DAppearance
            ChartTextAppearance cta = new ChartTextAppearance();
            cta.Visible = true;
            //-2 signifies all rows or all columns
            cta.Row = -2;
            cta.Column = -2;
            cta.ChartTextFont = new Font("Arial", ((float)FontSize - 1.5f), FontStyle.Regular, GraphicsUnit.Point);
            cta.ItemFormatString = bMatchup ? "  " + sValueFormat : sValueFormat;
            cta.HorizontalAlign = StringAlignment.Center;
            cta.VerticalAlign = stack ? StringAlignment.Center : StringAlignment.Far;// Inside the bar for stack style
            chart.ColumnChart.ChartText.Add(cta);
             if (ValueAlignVerical)
                chart.ChartDrawItem += ultraChart1_ChartDrawItem;
                cta.HorizontalAlign = StringAlignment.Far;
                cta.VerticalAlign = stack ? StringAlignment.Center : StringAlignment.Center;// Inside the bar for stack style
