25
BaseOleDBRepository from Sample MyMail
Where can I find this definition in the Samples code?  Trying to use the MyMail sample as a starting point for a web project I am working on.  Since there is no Visual Studio solution for the sample projects that I have found, I cannot seem to find where in the code this is defined.
public
class EmailFolderRepository : BaseOleDBRepository<EmailFolderCollection>
Phil
  • 310
    Suggested Answer
    Phil,
    You are correct, there isn't a solution file for the samples.  The samples browser was built as a website using the 2.0 framework.  You could create a blank solution in VS and add an existing website to that solution.  This would give you the samples site wrapped by a solution file.
    The BaseOleDBRepository code can be found at /App_Code/CS/InfraRealty/Data within the samples website.  It looks like it was originally used in the InfraRealty (InfraProperties) project.  Sorry for any confusion.
    Ed
