sometimes max x-axis range missing in horizontal bar chart 3d, but appears most of the time. any idea? thanks.
actually one of the bar value is 12 still it didnt show the max range 12 in the axis. anyhow i will try the solution you suggested, many thanks.
The max range is not displayed, because it is between 2 intervals. If you want to be sure that the max range will show every time, you can set it custom with:
this.ultraChart1.Axis.X.RangeType = AxisRangeType.Custom;
this.ultraChart1.Axis.X.RangeMin = 0;
this.ultraChart1.Axis.X.RangeMax = 12;
Please click the image to see it completely, i highlighted the area where the issue is.
using barchart3d in my page, sometimes doesnt show range of x-axis, it is missing? thanks.
Can you provide a little more info about this issue? A screenshot will be good.
