222
Upgrading from 5.3 to 9.1
Hi Vince,
  I having so many issues once I upgrade my development system from Infragistics NetAdvantage 2005 Volume 3 CLR 2.0
to NetAdvantage for .NET 2009.1. It throws lot of error while building the web site.  I am showing some of them.
Error 1 'filter' is not a known CSS property name. D:\Websites\IGL_Dev\BOL_Module\App_Themes\BidSoft.css 16 2 D:\...\BOL_Module\
Error 2 'filter' is not a known CSS property name. D:\Websites\IGL_Dev\BOL_Module\App_Themes\BidSoft.css 21 2 D:\...\BOL_Module\
Error 3 'filter' is not a known CSS property name. D:\Websites\IGL_Dev\BOL_Module\App_Themes\BidSoft.css 33 2 D:\...\BOL_Module\
Error 4 'filter' is not a known CSS property name. D:\Websites\IGL_Dev\BOL_Module\App_Themes\BidSoft.css 41 2 D:\...\BOL_Module\
Error 81 Element 'ScriptManager' is not a known element. This can occur if there is a compilation error in the Web site. D:\Websites\IGL_Dev\BOL_Module\Forms\Default.aspx 116 34 D:\...\BOL_Module\
Error 82 Validation (HTML 4.01): Element 'services' is not supported. D:\Websites\IGL_Dev\BOL_Module\Forms\Default.aspx 117 42 D:\...\BOL_Module\
Error 83 Element 'ServiceReference' is not a known element. This can occur if there is a compilation error in the Web site. D:\Websites\IGL_Dev\BOL_Module\Forms\Default.aspx 118 50 D:\...\BOL_Module\
Error 84 Element 'UpdatePanel' is not a known element. This can occur if there is a compilation error in the Web site. D:\Websites\IGL_Dev\BOL_Module\Forms\Default.aspx 134 46 D:\...\BOL_Module\
Error 85 Validation (HTML 4.01): Element 'contenttemplate' is not supported. D:\Websites\IGL_Dev\BOL_Module\Forms\Default.aspx 135 46 D:\...\BOL_Module\
Error 86 Element 'DropDownList' is not a known element. This can occur if there is a compilation error in the Web site. D:\Websites\IGL_Dev\BOL_Module\Forms\Default.aspx 136 259 D:\...\BOL_Module\
Error 87 Element 'TextBox' is not a known element. This can occur if there is a compilation error in the Web site. D:\Websites\IGL_Dev\BOL_Module\Forms\Default.aspx 136 511 D:\...\BOL_Module\
Error 88 Element 'Button' is not a known element. This can occur if there is a compilation error in the Web site. D:\Websites\IGL_Dev\BOL_Module\Forms\Default.aspx 136 614 D:\...\BOL_Module\
Error 89 Element 'TextBox' is not a known element. This can occur if there is a compilation error in the Web site. D:\Websites\IGL_Dev\BOL_Module\Forms\Default.aspx 136 864 D:\...\BOL_Module\
Error 90 Element 'TextBox' is not a known element. This can occur if there is a compilation error in the Web site. D:\Websites\IGL_Dev\BOL_Module\Forms\Default.aspx 136 1022 D:\...\BOL_Module\
I am not sure what's going on.
Please I let me know where the folder  aspnet_client --> Infragistics --> 20091CLR20 supposed to be in the solution.
I replaced the old folder with new Infragistics folder.
It was aspnet_client --> system_web --> 2_0_50727 --> “ig_common” and “Themes”
I replaced those as per
aspnet_client --> infragistics --> 20091CLR20 --> “Scripts” and “Styles”
aspnet_client --> system_web--> 20091CLR20 --> “Scripts” and “Styles”
Please let me know if you need further detail about that.
Thank you in advance
Saravanan
