Is there any easy way to add column summaries to the grid, other than manually writing code for each column? I know the Ultra Data Grid has this feature but can not find it on the Web Data Grid.
Thanks.
Can you show an example of caluclating the total, the max, the in and the average of a column and show it in the footer or header ? It looks like it's easy but I'm very new in infragistics netadavantage.
by the way will the results be refreshed automatically as the date column changes ? just like the video about the amazing Wingrid ?
thank you very much.
karim.
If you are referring to aggregate function support in the header/footer (like calculating min / max / average values), this is currently not supported out of the box, but you can easily calculate the values and set the respective header/footer content.
Let me know if you need any further help about this.
Angel
