325
CompositeChart aligning composite legend to the right... how?
I've hit a bit of a brick wall, I have a composite chart using an X, Y and Y2 axis.  It has a ColumnChart and LineChart rendering perfectly.
I'm also rendering two appropriate legends, and positioning them using bounds, at present in the upper left corner.
What I want to do is reserve 20% of the entire chart space to put the legends on the right side of the chart.
I haven't got a clue where I should start in order to achieve this....?
  • 325
    Verified Answer
    Found the answer.  At first I was trying to use chart.Axis.X.Extent, but this wasn't doing anything.
    I needed to mark the extents on my AxisElement I was manually adding to the chart layers.
