<asp:UpdatePanel runat="server" ID="uppnl1" ChildrenAsTriggers="true" UpdateMode="Conditional"> <ContentTemplate> <ig:WebDropDown ID="ddlCheck" runat="server" DataKeyFields="DPCK_ID" DataSourceID="DealerChecksODS" DropDownAnimationDuration="1200" DropDownAnimationType="EaseOut" DropDownContainerHeight="200px" DropDownContainerMaxHeight="400px" DropDownContainerWidth="270px" DropDownOrientation="Default" EnableDropDownAsChild="True" MultipleSelectionType="Checkbox" PageSize="0" TextField="DPCK_CheckNumber" ValueField="DPCK_ID" BorderStyle="Solid" BorderWidth="1px" Height="20px" Width="130px" ToolTip="Select a check for batching" AutoPostBack="true" > <Items> <ig:DropDownItem Selected="true" Value="" Text="<Choose Check>" /> </Items> <DropDownItemBinding TextField="DPCK_CheckNumber" ValueField="DPCK_ID" /> <HeaderTemplate> <div class="dealerCheckhdr">Deposit Checks</div> </HeaderTemplate> <ItemTemplate> <span class="dealerCheckttl"><%#DataBinder.Eval(Container.DataItem, "DPCK_CheckNumber")%></span>: <%#String.Format("{0:c}", DataBinder.Eval(Container.DataItem, "DPCK_CheckAmount"))%> </ItemTemplate> <AutoPostBackFlags SelectionChanged="On" ValueChanged="On" /> </ig:WebDropDown> </ContentTemplate> </asp:UpdatePanel>
Code Behind
Private Sub WireEvents() AddHandler ddlCheck.SelectionChanged, AddressOf ddlCheck_SelectionChanged AddHandler ddlCheck.ValueChanged, AddressOf ddlCheck_ValueChanged End Sub
Protected Sub Page_Init(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Init WireEvents() End Sub
Protected Sub ddlCheck_SelectionChanged(ByVal sender As Object, ByVal e As Infragistics.Web.UI.ListControls.DropDownSelectionChangedEventArgs) Dim i As Integer = 5 End Sub Protected Sub ddlCheck_ValueChanged(ByVal sender As Object, ByVal e As Infragistics.Web.UI.ListControls.DropDownValueChangedEventArgs) Dim i As Integer = 5 End Sub
I put break points on the Int=5 lines and neither of them are hit at any time no matter what. I followed the example on the samples site for ServerEvents and still nothing. Also one other thing,
<ig:DropDownItem Selected="true" Value="" Text="<Choose Check>" /> does not show up in the drop down. I would like this to be the initially selected item. This item should not be in the template when you actually click the drop down to open it. I tried tapping into DataBound event
Public Sub ChecksDataBound(ByVal sender As Object, ByVal e As EventArgs) 'ddlCheck.Items.Insert(0, New DropDownItem("<Choose Check>")) End Sub
That add the item the way I like, except that it ALSO creates a blank template item which is definitely not what I want. Any help is always appreciated.
Code On,
~ck
Hi anok,
I have created a sample WebSite for you where the WebDropDown is in a user control, and the control is added to Default.aspx. SelectionChanged server-side event is defined as well, and if you put a breakpoint , it will be hit.
The website is attached.
Hope it helps,
Angel
Hello
I have the dropdown and selectedvalue change event in the User control and I am adding the User control to my main aspx page. So it is still not fireing the event.
I have set the AutoPostBack=false and ValueChange=on but it still does not work.
If you are a licensed customer:
To download the service release, log in to
‘My IG’ and select ‘Keys & Downloads’. Select the appropriate tab for this product; then the license key. The available service releases (Hot Fixes) should now be listed on the page
If you use a Trial license you need to create a support request, so that a Development Support Engineer can send you directly the link with the service release download.
http://ko.infragistics.com/support/submitrequest.aspx
How can I upgrade? Is there any link?
