I try to use the WebScheduleInfo, the WebScheduleSQLClientProvider and the WebMonthView. I created a SQLDataSource on my page. I set my SQL string connection to the WebScheduleSQLClientProvider. The string connction works for my application but not for the part with the WebSchedule.
The user is David and I have an error on the openning of the database with the user "sa"
Why ?
Do I have forget something ?
Regards.David
The following steps may help,
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-wpf/44706/how-to-limit-which-columns-in-a-datatable-to-display#44706
However if you are using Master Pages it may not be possible for the WebScheduleSqlClientProvider to find the SqlDataSource control (the ID will be mangled), in which case you pass the ConnectionString to the WebScheduleSqlClientProvider directly. The following thread and reply describes calling Connect to do that,
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/46025/ultranavigationbar-how-to-bind-with-objects#46025
That call needs to go near the start of Page_Load or someplace similarly early in the page lifecycle.
Depending on what the security settings in your connection string are, you may want to consult the SQL Server help topics in this section of the online help for explanations of using impersonation, etc.,
https://ko.infragistics.com/help/aspnet/web-deploying-webschedule-controls-and-components-landing
However, I would say that if you are getting an error saying it tried to connect as "sa" then most likely it is trying to establish its default connection because it never received the connection string you're trying to give it (frequently this is because it couldn't find the SqlDataSource on the master page but it could be because the connection string arrives too late, such as after WebSchedule tries to fetch data).
HTH,
Hi Derek,
Thanks for your answer. I try to set the properties directly in code and it now works.But I have another problem. I've got this error when I save an appointment.
DataProvider Exception adding Activity to database : Nom d'objet 'Resource' non valide
I have no table called "Resource" but mine is called "User" and I don't want to have 2 classes which have the same behaviour.So is it possible to redirect the WebscheduleInfo or WebScheduleSQLClientProvider ton another class ?
RegardsDavid
Derek,
I succeed to connect but with only one resource. By default I see the schedule of resource "999"
I wonder how I can choose a resource and see schedule of another resource. Is it possible with a combo box which contains the list of resources ?Could you help me to find an issue ?
Regards
David
ptitdave1978 said:I wonder how I can choose a resource and see schedule of another resource. Is it possible with a combo box which contains the list of resources ?
This sample shows just such a combo box,
https://ko.infragistics.com/samples/aspnet/schedule/full-page-sample
I believe the ASP.NET samples should be installed beneath either your My Documents\Infragistics folder in Win XP or \Users\Infragistics in Vista so you can examine the source for the WebFeatureBrowser / WebSchedule / FullPageSample.
Hi Derek
Thanks for your answer. I found the sample "FullPAgeSample" and I set the WebScheduleInfo1.ActiveResourceName. It works.
Thanks a lot.
I go on on my project and I ll come back to you if I have anothers questions.
