After upgrading some ASP.NET projects from Visual Studio 2003 to VS 2008 and .NET Framework 3.5, i tried to upgrade the Netadvantage components (Webgrid, Webnavigator) from 2001 to 2007 Volume2.
I chanched all the assembly references but in the design view of VS, Webnavigator displays the following error message:
'Infragistics.WebUI.UltraWebnavigator.Styles' must have items of type 'Infragistics.WebUI.UltraWebnavigator.Style'. 'Infragistics.WebUI.UltraWebnavigator.Style' is tyle of 'System.Web.UI.HtmlControls.HtmlGenericControl'.
Here the code:
<Styles> <ignav:Style Cursor="hand" BorderWidth="2px" BorderStyle="Outset" ForeColor="Black" BackColor="LightGray" CssClass="IslandClass"></ignav:Style> <Infragistics.WebUI.UltraWebNavigator.Style Cursor="Hand" BackColor="LightGray" BorderWidth="2px" BorderStyle="Outset" CssClass="IslandClass" ForeColor="Black"></Infragistics.WebUI.UltraWebNavigator.Style> </Styles>
Any ideas?
Hi all,
Just to confirm that vnvenkatesh's answer is right on the spot.
Infragistics.WebUI.UltraWebNavigator.Style has to be replaced with ignav:Style in the tags and everything should work fine.
Best Regards,
Petar Ivanov Developer Support Engineer Infragistics, Inc. http://ko.infragistics.com/support
Though this is a very late reply would help some body who is having similar problem.
As it is upgrade from Infragisitcs2 to Infragistics35 the Line 'Infragistics.WebUI.UltraWebnavigator.Styles' has to be replaced with 'ig:Styles' where ig is the tagname for the assembly reference.
Regards,Venkatesh
