110
Images do not show up after adding to viewer
Good afternoon,
I am trying to load images into an ImageViewer control from a database table that has the images stored in a binary column. After determining I can't just bind the imageviewer directly (right?), I wrote some code to pull each image in, write them out to a temp file, and then add each of those items into the imageviewer.
When I did a quick test of adding an image into the imageviewer during the page load, it worked fine. However in this case I will not be loading the images until after a certain record is selected. I am getting no errors, but I'm thinking perhaps the images are not showing up due to this happening sans post perhaps? I placed the imageviewer control inside an UpdatePanel and called Update() after adding the images, as was suggested in another post, but this didn't fix anything. Any ideas?
         currentImage = 1
        Dim docID As Integer
        Dim docDB As String
        Dim myRow As DataRow
        For Each myRow In docIDs.Tables(0).Rows()
            docID = myRow.Item(0)
            docDB = myRow.Item(4)
            Dim ConnectionString As String = "Data Source=XXXXXXX;Persist Security Info=True;Initial Catalog=" & docDB & ";User ID=XXXXXXX;Password=XXXXXXX"
            Dim cn As New SqlClient.SqlConnection(ConnectionString)
            Dim cmd As SqlClient.SqlCommand
            Dim dbImage As Byte() = Nothing
            cmd = New SqlClient.SqlCommand("SELECT data FROM documents_storage WHERE document_id = " & docID, cn)
            cmd.Connection.Open()
            Try
                dbImage = cmd.ExecuteScalar()
                If (Not (dbImage Is Nothing)) Then
                    Dim stmBLOBData As New System.IO.MemoryStream(dbImage)
                    cmd.Connection.Close()
                    'Take this and save to file.
                    Dim outStream As System.IO.FileStream = System.IO.File.OpenWrite(My.Computer.FileSystem.CurrentDirectory & "/images/" & currentImage & ".jpg")
                    stmBLOBData.WriteTo(outStream)
                    outStream.Flush()
                    outStream.Close()
                    'Return (stmBLOBData)
                End If
            Catch ex As Exception
                MsgBox(ex.ToString, MsgBoxStyle.Critical)
            End Try
            currentImage = currentImage + 1
        Next
        Dim imgs() As String = System.IO.Directory.GetFiles(My.Computer.FileSystem.CurrentDirectory & "\images", "*.jpg")
        For Each img As String In imgs
            imageViewer.Items.Add(New Infragistics.Web.UI.ListControls.ImageItem(My.Computer.FileSystem.CurrentDirectory & System.IO.Path.GetFileName(img), "", ""))
        Next
        imageViewer.SelectedIndex = 0
        UpdatePanel.Update()
Note that most of this is just test code so not really prettied up yet, and thus the images are simply named 1.jpg, 2.jpg, etc.
