Hi All,
I've got a problem with events getting fired on WebDropDown and WebDataTree when they are used in an UpdatePanel. Without UpdatePanels, everything seems fine.
I have a WebDropDown on a page. The WebDropDown is sat in an UpdatePanel - UpdatePanel1.I also have a WebDataTree. The WebDataTree is also sat in an UpdatePanel - UpdatePanel2.
I am handling the WebDropDown_SelectionChanged event. I am also handling the WebDataTree_CheckBoxSelectionChanged event.
When the page is first displayed, my WebDropDown gets bound to a DataTable. The WebDataTree is set at design time.
I am doing the following in the page:
Run 1
1. Check a node in the WebDataTree. It raises the CheckBoxSelectionChanged event back to the server.2. Change the WebDropDown selected value. The SelectionChanged event is raised followed by the CheckBoxSelectionChanged event - but I did not even check anything!!!!
Run 2
1. Change the WebDropDown selected value. The SelectionChanged event is raised (no CheckBoxSelectionChanged is raised).2. Check a node in the WebDataTree. It raises the CheckBoxSelectionChanged event back to the server. The SelectionChanged event is raised also!!!!!!
Both the UpdatePanels properties are set as:ChildrenAsTriggers = FalseUpdateMode = Conditional
WebDropDown properties are set as:AutoPostBackFlags SelectionChanged = On ValueChanged = Off
DisplayMode = DropDownListEnableAutoComplete = FalseEnableAutoFiltering = ServerEnableDropDownAsChild = TrueEnableLoadOnDemand = TrueMultipleSelectionType = Checkbox
WebDataTree properties are set as:AutoPostBackFlags CheckBoxSelection = On
CheckboxMode = BiStateEnableAjax = TrueEnableConnectorLine = TrueSelectionType = Single
I've attached a sample application.
Am I doing something wrong or is this a problem?? Any ideas?
Andez
Thank you! Worked for me too :)
Hmm, looks like I am being a bit of a <div>.
You need to call the Update() method of the panel manually if you not automatically updating (UpdateMode = Conditional) perhaps?
Yep, definately did the job. Not an IG issue but someone may come across something similar :-/
