How would I go about setting the CaptionText of a webdialogwidow from javascript?
You may get reference to Infragistics.Web.UI.Header object by get_header() member function of dialog and use setCaptionText(text) member function of header. Below is example:
<script type="text/javascript"> function dialogLoaded(dialog) { dialog.get_header().setCaptionText('loaded'); } function setCaption() { var dialog = $find('<%=WebDialogWindow1.ClientID%>'); dialog.get_header().setCaptionText('from button'); }</script><ig:WebDialogWindow ID="WebDialogWindow1" runat="server"> <ClientEvents Loaded="dialogLoaded" /></ig:WebDialogWindow><input type="button" value="set caption" onclick="setCaption()" />
