While upgrading from NetAdvantage 2006.2 to 2007.3 (CLR2.x) using the project upgrade utility I loose all characters in text properties such as webtextedit-control. This happens to all charcters with extended ascii codes above 128, such as german charcters ä,ü.ö etc.
I have posted this to Infragistics support before and supplied a project with just one page to reproduce the problem. But the support could not reproduce the problem and they have no suggestion (!!!) what I can to to solve the problem.
Has anybody else a idea what happens here (language settings semms not to be a problem) ?
Thanks, Markus
I got the error while upgrading to 2007.3. In the newest hotfix the problem is fixed (check infragistic notes). For me the problem is solved.
I also get the error.....
-> I just have to "search an replace" the hole project for the corrupted text....
I get the same error....
