Can someon point me to a example of databinding to the radial gauge? I have not found any good examples.
If you have a radial gauge, for example, you need to create a RadialGaugeScale and add a RadialGaugeNeedle. You can then set a value on the needle.
Here's a good example that might help you:http://help.infragistics.com/NetAdvantage/ASPNET/2010.3/CLR4.0/?page=WebGauge_Web_Creating_a_Radial_WebGauge_Using_Code.html
if there is no facility to bind the value from database. Let me know how to set a value.
e.g. i have taken UltraGauge1 on the aspx page just drag and drop,
I wd like to assign a value to it , now i am change the value using ValueString="80" in the aspfile, same thing i have to do using codeing.
Please suggest
the gauge is not a databound control, since in most cases there is only one dynamic value to be displayed (the needle value), there's no reason to have a DataSource property.
if you are getting a single value from a database, it can be assigned to the needle value in code when it's retrieved, but there's no databinding necessary.
