how do you get iFrame of ContentPane through JAVASCRIPT and set the iFrame'src attribute?
Hi Joe,
The simplest way to change url, is to use set_contentUrl, however, get_iframe().src is also possible.Note: ContentUrl should be set on server, otherwise, ContentPane will not have iframe object and there is nothing to set.Below is example.
<ig:WebDialogWindow ID="WebDialogWindow1" runat="server" Width="300px" Height="300px"> <ContentPane ContentUrl="http://www.google.com"></ContentPane></ig:WebDialogWindow>
<script type="text/javascript">function changeUrl(){ var dialog = $find('<%=WebDialogWindow1.ClientID%>'); if(!dialog) return; // instance of $IG.LayoutPane class var cp = dialog.get_contentPane(); var old = cp.get_contentUrl(); var iframe = cp.get_iframe(); //old = iframe.src; cp.set_contentUrl('http://ask.com'); //iframe.src = 'http://ask.com';}</script><input type="button" value="change url" onclick="changeUrl()" />
