190
WebDialogWindow with UpdatePanel
I have a webgrid where I have a checkbox in the column header as well as in the detail rows.  When the user clicks on the checkbox (check all) in the header I have a jv script that checks all checkbox in the detail rows.  Since my webgrid has a lot of rows, it takes time to loop through.  What I did was I added a modal webdialogwindow to display a wait message.  But it does not seem to show the dialog box.  Here is my code:
function global_clicked(control, ctrlgrid1) {
    var oWebDialogWindow3 = $find('tbTest__ctl1_WebDialogWindow3');
    oWebDialogWindow3.set_windowState($IG.DialogWindowState.Normal, true);
    var grid = igtbl_getGridById(ctrlgrid1.id);
    for (i = 0; i < grid.Rows.length; i++) {
        grid.Rows.getRow(i).getCellFromKey('test').getElement().children[0].checked = control.check;
    oWebDialogWindow3.set_windowState($IG.DialogWindowState.Hidden);
Thanks for your help!
  • 95
    Hi Sam,
    I have the same problem. I have tried so many ways. Web dialog window does not show up at all.
    Did you find the solution? If so, please provide the answer.
  • 24497
    Suggested Answer
    Hi Sam,
    I suggest you to debug by using any other control/htmlElement instead of WebDialogWindow. I think that result will be exactly the same.
    If your function takes long time to execute and you want to modify/refresh html, then you may try to use another "thread".
    (skipping validations for null, it may look like)
    var show = "$find('tbTest__ctl1_WebDialogWindow3').set_windowState($IG.DialogWindowState.Normal, true)";
    window.setTimeout(show, 0);
    var hide = "$find('tbTest__ctl1_WebDialogWindow3').set_windowState($IG.DialogWindowState.Hidden)";
    window.setTimeout(hide, 0);
