I'm trying to set the colors of my columns in a stacked bar chart and can't seem to get it working. The code works in a regular column chart, but not a stacked one. This is the code I'm using:
Protected Sub UltraChart1_ChartDrawItem(ByVal sender As Object, ByVal e As Infragistics.UltraChart.Shared.Events.ChartDrawItemEventArgs) Handles UltraChart1.ChartDrawItem Dim box As Box = TryCast(e.Primitive, Box) If box Is Nothing Then Exit Sub End If If box.Path Is Nothing Then Select Case box.Column Case 0 box.PE.Fill = Color.Red box.PE.FillStopColor = Color.Red Case 1 box.PE.Fill = Color.Yellow box.PE.FillStopColor = Color.Yellow Case 2 box.PE.Fill = Color.Green box.PE.FillStopColor = Color.Green End Select End If End Sub
Can someone please point me in the right direction?
Thanks!
StackColumnChart boxes have their Path set to "Border.Title.Grid.Chart", so your select statement never gets hit. I think it would be better to change the condition to use Row and Column instead of Path.
if box.Row >=0 and box.Column>=0 thenselect ...
