I've been asked to move the tab strip from the bottom to the top of the control. Is this possible? I saw mention of possibly making it "vertical," which might do in a pinch, but I haven't been able to find in the documentation how to set that up.
That got it. Thx.
WebHtmlEditor uses <TABLE>. First row is toolbar, 2nd row is editing area and 3rd row is tab strip. So, it is possible to swap those rows and get any desired order. However, it is not a supported feature, application can do similar only on its own. Below is example for you:
<script type="text/javascript">function initEditor1(editor){ var tbl = editor._elem0; // or //if(!tbl) // tbl = document.getElementById('<%=WebHtmlEditor1.ClientID%>'); if(!tbl) return; var tbody = tbl.firstChild;// or tbl.tBodies[0] if(tbody.nodeName != 'TBODY') tbody = tbl.childNodes[1]; if(!tbody || tbody.nodeName != 'TBODY') return; var rows = tbody.childNodes;// or tbl.rows var i = (rows[0].nodeName == 'TR') ? 0 : 1 var row1 = rows[i + 1], row3 = rows[i + 2]; tbody.removeChild(row3); tbody.insertBefore(row3, row1);}</script><ighedit:WebHtmlEditor ID="WebHtmlEditor1" runat="server"> <ClientSideEvents Initialize="initEditor1" /></ighedit:WebHtmlEditor>
So, there is no way to move the Design / HTML buttons up above the content? Many times they are below the fold and difficult to get to. Can they be put in the Tool Bar?
There is no property in WebHtmlEditor related to that. That feature is not supported.
