I am using version 7.1.20071.1050. I have a column chart that is zero aligned. Is there a way to change the color of the zero line?
Thank you,
Chad
Makes sense...Thank you
Set chart.Axis.X.LineColor property. Since ZeroAligned only moves the existing X axis, all axis properties should still take effect.
