595
WebDropDown - Cannot clear selected item Client-Side
I've got the following code for clearing the selections and resetting the WebDropDown server side:
            foreach (Infragistics.Web.UI.ListControls.DropDownItem item in WebDropDown1.Items)
                if (item.Selected)
                    item.Selected = false;
            this.WebDropDown1.CurrentValue = "Please select...";
This works, although is very complex considering there should be an easy way to do this... i.e. WebDropDown1.SelectedIndex = -1 like a normal WinForm control. Even WebDropDown1.SelectedItems.Clear() would be better.
I'm now trying to do the same thing Client-Side. This is the code I have that doesn't work:
        function Reset()
            var dropDown = $find('<%=WebDropDown1.ClientID %>');
            var selectedList = dropDown.get_selectedItems();
            for (var i = 0; i< selectedList.length; i++)
                selectedList[i].set_selected(false);
            dropDown.set_currentValue("Please select...", false);
How can this be done client-side?
