I habe a PieChart and the labels is sometime inside the chart and i want all the Labels outside.
is it possible to this?
Thank u very much
try decreasing the value of the UltraChart1.PieChart.RadiusFactor property.
I use a 2D Pie Chart and i post a picture and you can see the percent und name are inside the Chart
Thanks very much
is this a 3D pie chart? if so, try downloading the latest hotfix, because recently we changed that behavior to push the labels outside the pie if there is space available.
if it's a 2D pie chart, i'm not sure why labels would be inside the chart, maybe you could post a picture?
