hello,
with ColumnSpacing i have space between each Column. And then with FillSceneGraph space between first Column and Y Axis but sincce i change that i have problem with the
ColumnChart.Axis.X.Labels.Layout.Padding = 5; some Labels (Date.ToShortDateString()) are display (07.08.2009) some labels partially like this : 07.08...
FillScene Event:
private void Chart_FillSceneGraph(object sender, FillSceneGraphEventArgs e) { Axis yAxis = e.Grid["Y"] as Axis; foreach (Primitive currentPrimitive in e.SceneGraph) { Line l = currentPrimitive as Line; if (l != null && l.p1.Y == l.p2.Y) { l.p1.X = yAxis.startPoint.X; } }
PRELOAD FILE:
<?xml version="1.0" encoding="utf-8" ?><igchart:UltraChart BackColor="White" ChartType="ColumnChart" BackgroundImageFileName="" BorderColor="Black" BorderWidth="0px" EmptyChartText="Data Not Available. " Version="9.1"> <Axis> <PE ElementType="None" Fill="Cornsilk" /> <X Extent="58" LineThickness="1" TickmarkInterval="0" TickmarkStyle="Smart" Visible="True" RangeMin="0" RangeMax="0"> <Margin> <Far Value="3.0303030303030303" /> </Margin> <MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1" Visible="True" /> <MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1" Visible="False" /> <Labels Font="Microsoft Sans Serif, 7.8pt" FontColor="black" HorizontalAlign="Near" ItemFormatString="<ITEM_LABEL>" Orientation="VerticalLeftFacing" VerticalAlign="Center"> <SeriesLabels Font="Microsoft Sans Serif, 7.8pt" FontColor="black" HorizontalAlign="Center" Orientation="Horizontal" VerticalAlign="Center"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> </X> <Y Extent="60" LineThickness="1" TickmarkInterval="10" TickmarkStyle="Smart" Visible="True" RangeMin="0" RangeMax="0"> <MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1" Visible="True" /> <MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1" Visible="False" /> <Labels Font="Verdana, 9pt" FontColor="black" HorizontalAlign="Far" ItemFormatString="<DATA_VALUE:00.##>" Orientation="Horizontal" VerticalAlign="Center"> <SeriesLabels Font="Verdana, 9pt" FontColor="black" HorizontalAlign="Center" Orientation="VerticalLeftFacing" VerticalAlign="Center"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> </Y> <Y2 LineThickness="1" TickmarkInterval="10" TickmarkStyle="Smart" Visible="False"> <MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1" Visible="True" /> <MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1" Visible="False" /> <Labels Font="Verdana, 9pt" FontColor="black" HorizontalAlign="Near" ItemFormatString="<DATA_VALUE:00.##>" Orientation="Horizontal" VerticalAlign="Center" Visible="False"> <SeriesLabels Font="Verdana, 9pt" FontColor="black" HorizontalAlign="Center" Orientation="VerticalLeftFacing" VerticalAlign="Center"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> </Y2> <X2 LineThickness="1" TickmarkInterval="0" TickmarkStyle="Smart" Visible="False"> <MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1" Visible="True" /> <MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1" Visible="False" /> <Labels Font="Verdana, 7pt" FontColor="Gray" HorizontalAlign="Far" ItemFormatString="<ITEM_LABEL>" Orientation="VerticalLeftFacing" VerticalAlign="Center" Visible="False"> <SeriesLabels Font="Verdana, 7pt" FontColor="Gray" HorizontalAlign="Center" Orientation="Horizontal" VerticalAlign="Center"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> </X2> <Z LineThickness="1" TickmarkInterval="0" TickmarkStyle="Smart" Visible="False"> <MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1" Visible="True" /> <MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1" Visible="False" /> <Labels Font="Verdana, 7pt" FontColor="DimGray" HorizontalAlign="Near" ItemFormatString="" Orientation="Horizontal" VerticalAlign="Center"> <SeriesLabels Font="Verdana, 7pt" FontColor="DimGray" HorizontalAlign="Center" Orientation="Horizontal" VerticalAlign="Center"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> </Z> <Z2 LineThickness="1" TickmarkInterval="0" TickmarkStyle="Smart" Visible="False"> <MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1" Visible="True" /> <MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1" Visible="False" /> <Labels Font="Verdana, 7pt" FontColor="Gray" HorizontalAlign="Near" ItemFormatString="" Orientation="Horizontal" VerticalAlign="Center" Visible="False"> <SeriesLabels Font="Verdana, 7pt" FontColor="Gray" HorizontalAlign="Center" Orientation="Horizontal" VerticalAlign="Center"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> </Z2> </Axis> <Data SwapRowsAndColumns="True"> </Data> <Border Thickness="0" /> <DeploymentScenario Scenario="FileSystem" ImageURL="../../../Content/ChartImages/Chart_#SEQNUM(100).png"ImageType="Png" FilePath="..\..\..\Content\ChartImages"></DeploymentScenario> <Tooltips Font-Bold="False" Font-Italic="False" Font-Overline="False" Font-Strikeout="False" Font-Underline="False" /></igchart:UltraChart>
Thanks for
you might have better results if you try changing the Orientation of your axis labels.
or, try:
Axis.X.Labels.Layout.Behavior = None
