Hi. Please refer the attachment. I need to show like this. One bar dashed and other is solid bordered. How can I do this? I tried but could not get dashed column(I got Both columns as solid). Please give the solution to achieve this.
Thanks in advance!
Sridhar
a single pixel dashed line can often appear blurry due to anti-aliasing. setting SmoothingMode=None on the chart will remedy this problem but may have some side effects like diagonal lines appearing pixelated.
This is a standard .net dash style and cannot be controlled. You can increase the thickness by setting PE.StrokeWidth on the box.
Hi
It works . Thanks. But please refer the attachment. The line is not clear as dashed(Small and thin). I need to increase the gap between lines but could not. I want it as clear dashed(Thick). Help me regarding this.
Thanks in advance.
you need to cast the primitive as a Box to set the line style.
Box box = p as Box;if (box != null){ box.lineStyle.DrawStyle = LineDrawStyle.Dash;}Also, the Row property value won't be at -2, you can omit that condition.
Hai
I used the following code in fillscenegraph event but dint get success. Can you please guide me to get the row=-2, column=1 as dotted line? Can you post the code to get this?
if (e.ChartCore.ChartType == ChartType.ColumnChart) { foreach (Primitive p in e.SceneGraph) { if (p.Path != null) { if (p is Box && p.Row == -2 && p.Column == 1) { //To set the box fill as transparent
p.PE.Fill = System.Drawing.Color.Transparent;
/*I dont know code how to get dotted line*/ }
