1004
Legend problem on line chart
i use following example on this page: http://help.infragistics.com/NetAdvantage/ASPNET/2009.1/CLR3.5/
to create line Chart but Legend ist empty. how i can display the legend?
  • 2265
    Not too sure which example your looking at as only partial url.
    Are you binding the chart to a DataTable or creating a custom series?
    Did you add the chart with the Chart Wizard?
    Also, is there any data in the chart?
    Is the legend drawn but there is no series data in it?
    This should display the legend:
    ultraChartData.Legend.Visible =
    True
    But you may have to add it manually with something like as follows for composite charts:
    Dim
    myLegend As New CompositeLegend()
    myLegend.ChartLayers.Add(cla)
    myLegend.Bounds = New
    System.Drawing.Rectangle(1, 83, 25, 17)
    myLegend.BoundsMeasureType = Infragistics.UltraChart.Shared.Styles.MeasureType.Percentage
    myLegend.PE.ElementType = Infragistics.UltraChart.Shared.Styles.PaintElementType.Gradient
    myLegend.PE.FillGradientStyle = Infragistics.UltraChart.Shared.Styles.GradientStyle.Horizontal
    myLegend.PE.Fill = System.Drawing.Color.Transparent
    myLegend.PE.FillStopColor = System.Drawing.Color.Transparent
    myLegend.Border.Thickness = 0
    Me.UltraChart1.CompositeChart.Legends.Add(myLegend)
    You will need to add each chart layer to the legend manually in the highlighted code.
