I am editing a DateTime field in a WebDataGrid and using the WebDateChooser as the Editor provider. This is all done statically in my web page and not in my code-behind. It works fine the after the first time the WebDataGrid is databound. If the user changes his selection criteria and it is bound a 2nd time, the Popup calendar no longer shows up and the field is edited as plain text.
<table align="center"> <tr> <td> <asp:UpdatePanel ID="upGetConfNums" runat="server"> <ContentTemplate> <table align="center"> <tr> <td class="label" align="right">Conf. #'s (separated by commas or spaces): </td> <td align="left"> <des:TextBox ID="tbConfList" runat="server" MaxLength="300" Width="750px" Height="18px" /> </td> </tr> <tr> <td align="right"> </td> <td align="left"> <des:Button ID="btnGetRecords" runat="server" Text="Get Records" onclick="btnGetRecords_Click" /> </td> </tr> </table> </ContentTemplate> <Triggers> <asp:AsyncPostBackTrigger ControlID="btnGetRecords" EventName="Click" /> </Triggers> </asp:UpdatePanel> </td> </tr> <tr> <td colspan="2" align="center"> <asp:UpdatePanel ID="upUpdateCallTimes" runat="server" Visible="True"> <ContentTemplate> <ig:WebDataGrid ID="wdgCMSVSVNCallDates" runat="server" Height="350px" Width="400px" AutoGenerateColumns="False" DataSourceID="sqldsCMSVSVNCallDates" DataKeyFields="Conf_Num" onrowupdated="wdgCMSVSVNCallDates_RowUpdated" onrowupdating="wdgCMSVSVNCallDates_RowUpdating" > <Behaviors> <ig:EditingCore> <Behaviors> <ig:CellEditing> <ColumnSettings> <ig:EditingColumnSetting ColumnKey="CallTime" EditorID="WebDateChooserProvider1" /> <ig:EditingColumnSetting ColumnKey="Conf_Num" ReadOnly="True" /> <ig:EditingColumnSetting ColumnKey="Category" ReadOnly="True" /> </ColumnSettings> <CellEditingClientEvents ExitedEditMode="cellEdited" /> </ig:CellEditing> </Behaviors> </ig:EditingCore> <ig:RowSelectors> </ig:RowSelectors> <ig:Activation> </ig:Activation> </Behaviors> <Columns> <ig:BoundDataField DataFieldName="Conf_Num" Key="Conf_Num"> <Header Text="Conf_Num" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="CallTime" Key="CallTime"> <Header Text="CallTime" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Category" Key="Category"> <Header Text="Category" /> </ig:BoundDataField> </Columns> <EditorProviders> <ig:WebDateChooserProvider ID="WebDateChooserProvider1" /> </EditorProviders> </ig:WebDataGrid> <asp:SqlDataSource ID="sqldsCMSVSVNCallDates" runat="server" ConnectionString="<%$ ConnectionStrings:Springwise %>" SelectCommand="GetCMSVSVNCallDatesByConfNumArray" UpdateCommand="UpdateVSVNWorkCallTime" SelectCommandType="StoredProcedure" UpdateCommandType="StoredProcedure"> <SelectParameters> <asp:Parameter Name="ConfNums" Type="String" DefaultValue="<ArrayOfString><string Conf_Num='~!@#$' /></ArrayOfString>" /> </SelectParameters> <UpdateParameters> <asp:Parameter Name="Conf_Num" Type="String" /> <asp:Parameter Name="CallTime" Type="DateTime" /> </UpdateParameters> </asp:SqlDataSource> </ContentTemplate> <Triggers> <asp:AsyncPostBackTrigger ControlID="btnGetRecords" EventName="Click" /> </Triggers> </asp:UpdatePanel> </td> </tr> </table>
Apparently, it was something going in in the RowUpdated or RowUpdating methods I had before I switched to committing to the DB after cell changes, which I did because I would not get commit when I had only 1 row. I had an e.Cancel() in RowUpdating, because I had some problems with getting null dates, but I had no null dates in the records I was currently working with. Maybe it was just having those methods performed.
