I am Using a Column chart , For one column the value is higher(like '45000') and for another column the value is comparatively lower(like '50') , in this scenario the bar for that lower value can't be seen in the graph.Is there any way to show the smaller value in the graph.
Since it's impossible to show a rectangle with height less than one pixel, you will not see the first column in your chart on a linear axis. However, you can change y axis to Logarithmic. See more information here:http://help.infragistics.com/Help/NetAdvantage/ASPNET/2009.1/CLR3.5/html/Chart_Linear_and_Logarithmic_Axes.html
