I want alway to have MajorGridLines/MinorGridLines on my Chart but sometime i didnt have it.
<igchart:UltraChart BackColor="White" EmptyChartText="Data Not Available." BorderWidth="0px" ChartType="BarChart" Version="9.1"> <Axis> <PE ElementType="None" Fill="Cornsilk" /> <X Extent="70" LineThickness="1" TickmarkInterval="50" TickmarkStyle="Smart" Visible="True"> <Margin> <Far Value="2.4896265560165975" /> </Margin> <MajorGridLines AlphaLevel="255" Color="Red" DrawStyle="Dot" Thickness="1" Visible="True" /> <MinorGridLines AlphaLevel="255" Color="Blue" DrawStyle="Dot" Thickness="1" Visible="true" /> <Labels Font="Verdana, 9pt" FontColor="black" HorizontalAlign="Far" ItemFormatString="<DATA_VALUE:00.##>" Orientation="VerticalLeftFacing" VerticalAlign="Center"> <SeriesLabels Font="Verdana, 9pt" FontColor="black" FormatString="" HorizontalAlign="Far" Orientation="VerticalLeftFacing" VerticalAlign="Center"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> </X> <Y Extent="140" LineThickness="1" TickmarkInterval="0" TickmarkStyle="Smart" Visible="True"> <MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1" Visible="True" /> <MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1" Visible="False" /> <Labels ItemFormatString="<ITEM_LABEL>" VerticalAlign="Center" WrapText="False" FontSizeBestFit="False" SeriesFormatString="<SERIES_LABEL>" ClipText="True" Font="Verdana, 7.8pt" Flip="False" ItemFormat="ItemLabel" FontColor="Black" Orientation="Horizontal" Visible="True" OrientationAngle="0" HorizontalAlign="Far"> <SeriesLabels Font="Verdana, 8pt" Visible="True" HorizontalAlign="Center" FontSizeBestFit="False" ClipText="True" FormatString="<SERIES_LABEL>" Orientation="VerticalLeftFacing" WrapText="False" Flip="False" FontColor="Black" VerticalAlign="Near" OrientationAngle="0"></SeriesLabels> </Labels> </Y> <Y2 LineThickness="1" TickmarkInterval="0" TickmarkStyle="Smart" Visible="False"> <MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1" Visible="True" /> <MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1" Visible="False" /> <Labels Font="Verdana, 7pt" FontColor="Gray" HorizontalAlign="Near" ItemFormatString="<ITEM_LABEL>" Orientation="Horizontal" VerticalAlign="Center" Visible="False"> <SeriesLabels Font="Verdana, 7pt" FontColor="Gray" HorizontalAlign="Center" Orientation="VerticalLeftFacing" VerticalAlign="Center"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> </Y2> <X2 LineThickness="1" TickmarkInterval="50" TickmarkStyle="Smart" Visible="False"> <MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1" Visible="True" /> <MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1" Visible="False" /> <Labels Font="Verdana, 7pt" FontColor="Gray" HorizontalAlign="Far" ItemFormatString="<DATA_VALUE:00.##>" Orientation="VerticalLeftFacing" VerticalAlign="Center" Visible="False"> <SeriesLabels Font="Verdana, 7pt" FontColor="Gray" FormatString="" HorizontalAlign="Far" Orientation="VerticalLeftFacing" VerticalAlign="Center"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> </X2> <Z LineThickness="1" TickmarkInterval="0" TickmarkStyle="Smart" Visible="False"> <MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1" Visible="True" /> <MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1" Visible="False" /> <Labels Font="Verdana, 7pt" FontColor="DimGray" HorizontalAlign="Near" ItemFormatString="" Orientation="Horizontal" VerticalAlign="Center" Visible="False"> <SeriesLabels Font="Verdana, 7pt" FontColor="DimGray" HorizontalAlign="Near" Orientation="Horizontal" VerticalAlign="Center"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> </Z> <Z2 LineThickness="1" TickmarkInterval="0" TickmarkStyle="Smart" Visible="False"> <MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1" Visible="True" /> <MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1" Visible="False" /> <Labels Font="Verdana, 7pt" FontColor="Gray" HorizontalAlign="Near" ItemFormatString="" Orientation="Horizontal" VerticalAlign="Center" Visible="False"> <SeriesLabels Font="Verdana, 7pt" FontColor="Gray" HorizontalAlign="Near" Orientation="VerticalLeftFacing" VerticalAlign="Center"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> </Z2> </Axis> <Border Thickness="0" /> <Tooltips BorderThickness="1" Overflow="None" FormatString="<DATA_VALUE:n0>" EnableFadingEffect="False" Format="DataValue" FontColor="Black" BorderColor="Black" Display="MouseMove" BackColor="AntiqueWhite" Padding="0"></Tooltips></igchart:UltraChart>
some Solution for this.
Not sure why you are getting Y axis gridlines instead of X, but this seems to work fine on my machine. Can you attach an entire project with all the references and code behind? Thanks
Sorry it was the bad Image and i didnt check it, now it is the good Image
The image that you attached is that of a stacked bar chart, however, your markup declares a BarChart instead. After I change the chart type to StackBarChart, I still see the gridlines properly. What I noticed in your image is that you have tickmark lines along the x axis. Our chart doesn't have this feature, so you must have written custom code to create those tickmarks. I suggest you look through that code, because it is possibly the cause of your gridlines not showing up.
