105
WebImangeVierwe - Serverside events
Hi
How do i setup a serverside event handler to capture ImageSelected event ?
  • 7694
    Normal 0 21 false false false BG X-NONE X-NONE MicrosoftInternetExplorer4
    You can handle server side event by two  ways.
    The first way is to  override the event OnInit. For example you  can take a look  at the sample code below:
    protected override void OnInit(EventArgs e)
    //here you  subsribe to SelectedIndexChanged event
            WebImageViewer1.SelectedIndexChanged +=
                new Infragistics.Web.UI.ListControls.ImageItemEventHandler(WebImageViewer1_SelectedIndexChanged);
        void WebImageViewer1_SelectedIndexChanged(object sender, Infragistics.Web.UI.ListControls.ImageItemEventArgs e)
            throw new NotImplementedException();
    The second way  is subscribe for event automatically with  visual  studio. You  just have to  double click on the event then event will be generate automatically. Please take a look  at the attached picture below.
    Hope this helps.
    Thanks.
    Ivan Baev
