325
Composite Chart Layer Order
I'm trying to do some layering work, and before my 2 charts are rendered need to place some boxes on the chart.  I've been reading up on chart layers and ordering trying to follow a few examples by creating 3 layers and adding them to the chart, then setting the layer order using UserLayerIndex and then implementing FillSceneGraph to draw the boxes I need in my custom layer .
The code I'm using is as follows:
void RenderCompositeChart(UltraChart chart, DataTable ColumnLineData, DataTable LineData, double StartAtY1, double EndAtY1, double StartAtY2, double EndAtY2, int
PageID)
// Combine the two existing data sets into a single dataset for the IG composite
// chart to use
DataTable
CombinedTable = RenderCombinedAxisDataTable(ColumnLineData, LineData);
chart.ChartType =
ChartType
.Composite;
ChartArea area = new ChartArea
chart.CompositeChart.ChartAreas.Add(area);
AxisItem xAxisColumn = new AxisItem(chart, AxisNumber
.X_Axis);
AxisItem xAxisLine = new AxisItem(chart, AxisNumber
.X_Axis);
AxisItem yAxis = new AxisItem(chart, AxisNumber
.Y_Axis);
AxisItem y2Axis = new AxisItem(chart, AxisNumber
.Y2_Axis);
xAxisColumn.DataType =
AxisDataType
.String;
xAxisColumn.SetLabelAxisType =
SetLabelAxisType
.GroupBySeries;
xAxisColumn.Labels.ItemFormat =
AxisItemLabelFormat
.ItemLabel;
xAxisLine.DataType =
AxisDataType
.String;
xAxisLine.SetLabelAxisType =
SetLabelAxisType
.ContinuousData;
yAxis.DataType =
AxisDataType
.Numeric;
yAxis.Labels.ItemFormat =
AxisItemLabelFormat
.DataValue;
yAxis.LineThickness = 1;
y2Axis.DataType =
AxisDataType
.Numeric;
y2Axis.Labels.ItemFormat =
AxisItemLabelFormat
.DataValue;
y2Axis.LineThickness = 1;
area.Axes.Add(xAxisColumn);
area.Axes.Add(xAxisLine);
area.Axes.Add(yAxis);
area.Axes.Add(y2Axis);
// Define two chart layers for drawing on
ChartLayerAppearance ColumnLayer = new ChartLayerAppearance
ColumnLayer.Key =
"ColumnLayer"
ChartLayerAppearance LineLayer = new ChartLayerAppearance
LineLayer.Key =
"LineLayer"
// Now, define the series for each layer... best way to do this
// is to iterate the measures and determine which axis it has been
// assigned to...
int
maIndex = -1;
foreach (MeasureAxis ma in
_gadget.MeasureAxis)
maIndex++;
// Define a series for the relevant column in the data table
NumericSeries maSeries = new NumericSeries
maSeries.Data.DataSource = CombinedTable;
maSeries.Label = ma.Name;
maSeries.Data.LabelColumn = CombinedTable.Columns[CombinedTable.Columns.Count - 1].ColumnName;
maSeries.Data.ValueColumn = CombinedTable.Columns[maIndex].ColumnName;
// Assign the series to the correct chart layer
if (ma.LayerAssignment == MeasureChartAssignment
.ASSIGNTO_LAYER1)
chart.Series.AddRange(
new ISeries
[] { maSeries });
ColumnLayer.Series.Add(maSeries);
if
(_gadget.Stacked)
DataColumn
colSeries = CombinedTable.Columns[maIndex];
double
colStackMinimum = 0;
double
colStackTotal = 0;
ValidateStackValues(colSeries,
ref colStackMinimum, ref
colStackTotal);
StartAtY1 =
Math
.Min(StartAtY1, colStackMinimum);
EndAtY1 =
Math
.Max(EndAtY1, colStackTotal);
else
new ISeries
[] { maSeries });
LineLayer.Series.Add(maSeries);
// Define the properties of each of the chart layers
ColumnLayer.AxisX = xAxisColumn;
ColumnLayer.AxisY = yAxis;
ColumnLayer.ChartArea = area;
if
(_gadget.Stacked)
ColumnLayer.ChartType =
ChartType
.StackColumnChart;
if (_gadget.Stacked100 == true
chart.StackChart.StackStyle =
StackStyle
.Complete;
else
ChartType
.ColumnChart;
ColumnLayer.ChartArea.PE.StrokeOpacity = 50;
LineLayer.AxisX = xAxisLine;
LineLayer.AxisY = y2Axis;
LineLayer.ChartArea = area;
LineLayer.ChartType = (_gadget.UseSmoothCurve ?
ChartType.SplineChart : ChartType
.LineChart);
chart.CompositeChart.ChartLayers.Add(ColumnLayer);
chart.CompositeChart.ChartLayers.Add(LineLayer);
chart.ColumnChart.SeriesSpacing = 0;
ChartLayerAppearance gridLayer = new ChartLayerAppearance
gridLayer.Key =
"GridRangeLayer"
chart.CompositeChart.ChartLayers.Add(gridLayer);
//Set the colour scheme for the chart
ApplyChartPalette(chart);
chart.Border.Thickness = 0;
chart.ColumnChart.NullHandling = Infragistics.UltraChart.Shared.Styles.
NullHandling
.DontPlot;
//Setting tooltip for chart
SetToolTip(chart);
CompositeLegend ColumnLegend = new CompositeLegend
ColumnLegend.ChartLayers.Add(ColumnLayer);
CompositeLegend LineLegend = new CompositeLegend
LineLegend.ChartLayers.Add(LineLayer);
chart.CompositeChart.Legends.Add(ColumnLegend);
chart.CompositeChart.Legends.Add(LineLegend);
// Reserve a 20% space for the legend
ResizeChart(chart);
int
FontSize = 12;
// Formatting, formatting, formatting! Let's try and tidy these suckers up!
Font verdana = new Font("Verdana", FontSize, GraphicsUnit.Pixel);
// I18CHECKED
chart.Axis.X.Labels.Font = verdana;
chart.Axis.Y.Labels.Font = verdana;
chart.Axis.Y2.Labels.Font = verdana;
// Make the legend 2 points smaller for now
Font legVerdana = new Font("Verdana", FontSize - 2, GraphicsUnit.Pixel);
// I18CHECKED
ColumnLegend.LabelStyle.Font = legVerdana;
LineLegend.LabelStyle.Font = legVerdana;
// Tickmark style cannot be set to 'Smart' (bug logged as CAS-04642-NCZJWZ) when range limits have been set. I have therefore lifted the smart calibration algorithm from infragistics
// so I can still use it
double
interval = 0;
double
interval1 = 0;
// Perform smart scaling
AxisSmartScale(
ref StartAtY1, ref EndAtY1, out
interval);
AxisSmartScale(
ref StartAtY2, ref EndAtY2, out
interval1);
ScaleAxis(chart, yAxis, StartAtY1, EndAtY1, interval);
ScaleAxis(chart, y2Axis, StartAtY2, EndAtY2, interval1);
int EndAtY2Val = (int
)EndAtY2;
int
EndAtY2Size = FontSize * (EndAtY2Val.ToString().Length + 1);
SetLabelAppearance(xAxisColumn,
TextOrientation
.VerticalLeftFacing);
SetLabelAppearance(yAxis,
TextOrientation
.Horizontal);
SetLabelAppearance(y2Axis,
TextOrientation
.Horizontal);
int maxLabelWidth = GetMaxColumnLabelDimension(ColumnLineData, verdana, true
SetLabelInterval(chart, ColumnLineData,
false
, xAxisColumn);
// Work out the extents we will need to place the legends to the right of the chart
Size
szy1Legend = GetLegendDimensions(ColumnLineData, FontSize - 2);
Size
szy2Legend = GetLegendDimensions(LineData, FontSize - 2);
// Which legend is going to be bigger, we will use that as our extent for the y-Axis'
int
yAxisExtent = (szy1Legend.Width > szy2Legend.Width ? szy1Legend.Width : szy2Legend.Width);
y2Axis.Extent = yAxisExtent;
BorderAppearance LegendBorder = new BorderAppearance
LegendBorder.Thickness = 0;
// This code is left in, in case we ever need to refer to the creation of a legend
// for the column data. It's been turned off for now because it's unnecessary given the
// current x-axis label display
ColumnLegend.Bounds =
new Rectangle
((width + EndAtY2Size) - yAxisExtent, 10, yAxisExtent - EndAtY2Size, szy1Legend.Height + 1);
ColumnLegend.BoundsMeasureType =
MeasureType
.Pixels;
ColumnLegend.Border = LegendBorder;
ColumnLegend.Visible =
false
if
(ColumnLegend.Visible)
LineLegend.Bounds =
new Rectangle
((width + EndAtY2Size) - yAxisExtent, szy1Legend.Height + 35, yAxisExtent - EndAtY2Size, szy2Legend.Height + 3);
else
LineLegend.Bounds =
new Rectangle
((width + EndAtY2Size) - szy2Legend.Width, 10, szy2Legend.Width - EndAtY2Size, szy2Legend.Height + 3);
// Reset the extent available to the legend to the Y2 axis one only
y2Axis.Extent = szy2Legend.Width;
LineLegend.BoundsMeasureType =
MeasureType
.Pixels;
LineLegend.Border = LegendBorder;
BorderAppearance ChartBorder = new BorderAppearance
ChartBorder.Thickness = 0;
chart.Border = ChartBorder;
chart.Visible =
true
// Shade differently any bars according to range or selection information
//chart.ChartDrawItem += new Infragistics.UltraChart.Shared.Events.ChartDrawItemEventHandler(chart_ChartDrawItem);
delegate(Object sender, Infragistics.UltraChart.Shared.Events.ChartDrawItemEventArgs
e)
chart_ChartDrawItem(sender, e, PageID);
// Add a custom layer if we need to
if
(_gadget.Ranges.Count != 0)
// Modify the order of drawing the layers...
chart.UserLayerIndex =
new string[] { "GridRangeLayer", "Default"
// Add the fill scene event to the chart
chart.FillSceneGraph +=
new FillSceneGraphEventHandler
(CompositeChart_FillSceneGraph);
However, the final result shows the custom layer being drawn last - over the top of the 2 chart layers.  Can anyone point me in the right direction?
