105
Webslider
Hi
How do i change the Plus,- and Minus button images. I tried changing the imageUrl properties designtime, and in design time they changed, but when i run the app. they are changed back to default.
Please help..
Regards
Flemming
  • 24497
    Suggested Answer
    Hi Flemming,
    I think you changed only ImageUrl property. However, WebSplitter uses different images for different states (focus, pressed, hover, disabled). If property for those states are missing, then default images are used and is splitter button are not in normal state, then those default images are used and they replace your image for "normal" state of button. It means you should provide images for those states, or you may set all properties to same image.
    <ig:WebSlider ID="WebSlider1" runat="server">
        <MinusButton ImageUrl="~/images/close.gif" DisabledImageUrl="~/images/close.gif" FocusImageUrl="~/images/close.gif" PressedImageUrl="~/images/close.gif" HoverImageUrl="~/images/close.gif" />
    </ig:WebSlider>
