1060
WebDropDown textbox width wrong if disabled
Hi - I'm using version 9.1.20091.2087 WebDropDown.  I need to disable/enable some WebDropDown control - but the 'text' area of the combo becomes too short (and I think the font size changes?) when it changes from enable to disabled.
This is very easy to reproduce - just paste this in as an aspx page - no code behind code needed.  Just run the sample and you will see the 'disabled' combo shows as a textbox with a border within the combobox...and it is too short!.  I just want it to 'grey' out the whole control but leave the contents alone!
Can you tell me what i can tweak to make this work?
thanks in advance!
<%@ Page Language="VB" %>
<%@ Register Assembly="Infragistics35.Web.v9.1, Version=9.1.20091.2087, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
  Namespace="Infragistics.Web.UI.ListControls" TagPrefix="ig" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<script runat="server">
</script>
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title></title>
</head>
<body>
<form id="form1" runat="server">
    <asp:ScriptManager ID="ScriptManager1" runat="server">
    </asp:ScriptManager>
    <div>
    <table width="500px">
      <tr>
        <td style="width:100px;">client name</td>
        <td style="width:400px;"><ig:WebDropDown ID="WebDropDown1" runat="server" Width="100%" CurrentValue="This is a test value to demonstrate the field length change" Enabled="false">
      </ig:WebDropDown></td>
      </tr>
      <tr>
        <td style="width:100px;">Job Number</td>
        <td style="width:400px;"><ig:WebDropDown ID="WebDropDown2" runat="server" Width="100%" CurrentValue="This is a test value to demonstrate the field length change" Enabled="true">
      </tr>
    </table>
    </div>
    </form>
</body>
</html>
